Introduzione
Use this guide to remove and replace the volume wheel on the Logitech G915 TKL keyboard. The volume wheel may need to be replaced if it's come loose due it breaking and is no longer working properly.
A Phillips #00 Screwdriver is necessary to complete this guide.
Cosa ti serve
Turn the keyboard around and peel back the Logitech sticker near the top center of the keyboard, as well as the plastic layer underneath.
Unscrew the two 2.5 mm #0 Phillips screws circled in the picture provided.
Remove the backplate by grabbing the notch to the right and pulling up.
Altre 3 persone hanno completato questa guida.
2Commenti sulla guida
Where tf do you get the scroll bar thing from?
Did you have any luck?
