Salta al contenuto principale
Logitech G915 TKL G1-G8 Key Replacement
Cosa ti serve
  1. Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: passo 1, immagine 1 di 3 Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: passo 1, immagine 2 di 3 Logitech G915 TKL G1-G8 Key Replacement, Remove the keycaps: passo 1, immagine 3 di 3
    • Remove all the keycaps.
    • While it can be done barehanded, use of a flat tool to remove the keycaps or use a keycap puller is recommended to prevent damage.
  2. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the front: passo 2, immagine 1 di 1
    • Unscrew the front 2mm #00 Phillips screws found here.
  3. Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: passo 3, immagine 1 di 3 Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: passo 3, immagine 2 di 3 Logitech G915 TKL G1-G8 Key Replacement, Take out the battery: passo 3, immagine 3 di 3
    • Remove the battery.
    • This will require the removal of the back sticker and unscrewing the two 2.5mm #0 Phillips screws circled.
  4. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the back: passo 4, immagine 1 di 1
    • Remove the remaining 2mm #00 Phillips back screws.
    • 3 screws are hidden under the rubber rests of the keyboard.
  5. Logitech G915 TKL G1-G8 Key Replacement, Unscrew the motherboard: passo 5, immagine 1 di 1
    • Remove the 2mm #00 Phillips motherboard screws.
    • The G1-G8 keys are held in place by the motherboard itself. Once the motherboard is detached, they can be easily removed and replaced by hand.
Conclusione
Altre 2 persone hanno completato questa guida.
Brandon Souza
Membro da: 03/13/23
151 Reputazione
1 Guida realizzata
5Commenti sulla guida
I can't find anywhere to buy a replacement key, can you point to a place where this is available?.
Magnus - Replica
"Once the motherboard is detached, they can be easily removed and replaced by hand."
Except you can't! The motherboard and all the key switches are slightly overlapped. Unless you de-soldering all the switch, you can not change the G keys. Stupid solution from Logitech in a such expensive keyboard
János G. - Replica
Do i need soldering for my spacekey stabilizers since one fell out. Or is it an easy fix?
pannar1 pannar1 - Replica
Based on the images provided with the Guide I can't tell.
But you can create a question in the Forum so I, or someone else can help you there more precisely, you can upload close-up images there which will help helping you. :)
Felix -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 157
Tutti i Tempi: 5,718
