Salta al contenuto principale
Logitech G915 TKL Battery Replacement
Cosa ti serve
  1. Logitech G915 TKL Battery Replacement, Battery: passo 1, immagine 1 di 2 Logitech G915 TKL Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the keyboard around and peel back the Logitech sticker near the top center of the keyboard, as well as the plastic layer underneath.
    • Unscrew the two 2.5 mm #0 Phillips screws circled in the picture provided.
    • Remove the backplate by grabbing the notch to the right and pulling up.
  2. Logitech G915 TKL Battery Replacement: passo 2, immagine 1 di 2 Logitech G915 TKL Battery Replacement: passo 2, immagine 2 di 2
    • Carefully unplug the battery connector, pulling away the plastic part using your fingers.
  3. Logitech G915 TKL Battery Replacement: passo 3, immagine 1 di 1
    • Put in your replacement battery.
Conclusione
Ethan Bedard
Membro da: 03/13/23
485 Reputazione
3 Guide realizzate
3 Commenti
where do you buy the battery?
luke dollard - Replica
This guide is great, but mentioning what kind of battery to purchase for the keyboard would make it infinitely better...
Darbii Rue - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 155
Tutti i Tempi: 2,619
