Salta al contenuto principale
Logitech G910 Lights Replacement
Cosa ti serve
  1. Logitech G910 Lights Replacement, Lights: passo 1, immagine 1 di 1
    • Unplug the keyboard from the computer.
  2. Logitech G910 Lights Replacement: passo 2, immagine 1 di 1
    • Flip the keyboard and unscrew the 15 back screws. The screws in the palm rest must be unscrewed and the palm rest removed to access the 6 screws at the bottom of the keyboard. (There are 2 lengths of screws the shorter ones are for the palm rest) There are also 2 screws under the nonslip pads of the palm rest.
  3. Logitech G910 Lights Replacement: passo 3, immagine 1 di 1
    • Release the front part using a spudger or flat screwdriver to gently pry. Lift off carefully.
  4. Logitech G910 Lights Replacement, Lift the film: passo 4, immagine 1 di 2 Logitech G910 Lights Replacement, Lift the film: passo 4, immagine 2 di 2
    • Gently lift up the plastic film in the top right corner.
Conclusione
Altre 5 persone hanno completato questa guida.
3 Commenti
So what do I do after I take apart my keyboard?
CuddlyZebesian - Replica
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola -
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
squallloire -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 96
Tutti i Tempi: 6,064
