Salta al contenuto principale
Logitech G602 Scroll Wheel Replacement
Cosa ti serve
  1. Logitech G602 Scroll Wheel Replacement, Scroll Wheel Spring: passo 1, immagine 1 di 1
    • Use a blue spudger to pry off all 4 mouse feet from under of mouse.
  2. Logitech G602 Scroll Wheel Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm ) from under the mouse feet.
  3. Logitech G602 Scroll Wheel Replacement: passo 3, immagine 1 di 2 Logitech G602 Scroll Wheel Replacement: passo 3, immagine 2 di 2
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  4. Logitech G602 Scroll Wheel Replacement: passo 4, immagine 1 di 1
    • Use the black spudger to move the tip of the metal spring off of the wheel.
    • The scroll wheel will not actually be removed — instead, the adjustment to the metal spring will test the wheel's usability.
    No idea what this is supposed to mean. The name of this guide is "replacement". The final instruction here is to "test the wheel's usability"?
    Felix - Replica
Conclusione
Altre 8 persone hanno completato questa guida.
2 Commenti
I recently received an approximately 2 year old Logitech g602 mouse. Its scroll is non-functional, either up or down. I do seem to be able to scroll minimally if I press the scroll wheel down. I was wondering if you know how this might be fixed. Anything is appreciated.
Adrian Thomas Rodriguez - Replica
I need a new wheel for this mouse. Where can I buy it? I could not see anyone who sell it
Josefa Parafina - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 84
Tutti i Tempi: 7,952
