Salta al contenuto principale
Logitech G502 Proteus Core Cable Replacement
Cosa ti serve
  1. Logitech G502 Proteus Core Cable Replacement, Cable: passo 1, immagine 1 di 2 Logitech G502 Proteus Core Cable Replacement, Cable: passo 1, immagine 2 di 2
    • Use a hairdryer to heat three mouse feet briefly.
    • Each mouse foot should take 7-8 seconds to heat up.
  2. Logitech G502 Proteus Core Cable Replacement: passo 2, immagine 1 di 3 Logitech G502 Proteus Core Cable Replacement: passo 2, immagine 2 di 3 Logitech G502 Proteus Core Cable Replacement: passo 2, immagine 3 di 3
    • Remove the mouse feet gently.
    • Avoid bending the mouse feet.
  3. Logitech G502 Proteus Core Cable Replacement: passo 3, immagine 1 di 2 Logitech G502 Proteus Core Cable Replacement: passo 3, immagine 2 di 2
    • Use a screwdriver to remove the four 12.5 mm screws.
  4. Logitech G502 Proteus Core Cable Replacement: passo 4, immagine 1 di 3 Logitech G502 Proteus Core Cable Replacement: passo 4, immagine 2 di 3 Logitech G502 Proteus Core Cable Replacement: passo 4, immagine 3 di 3
    • Use a spudger to pry open the bottom case.
    • A screwdriver is shown in the photo but screwdrivers shouldn't be used for prying. They might accidentally damage internal components with a slip.
  5. Logitech G502 Proteus Core Cable Replacement: passo 5, immagine 1 di 2 Logitech G502 Proteus Core Cable Replacement: passo 5, immagine 2 di 2
    • Raise the tabs to disconnect the ribbon.
  6. Logitech G502 Proteus Core Cable Replacement: passo 6, immagine 1 di 2 Logitech G502 Proteus Core Cable Replacement: passo 6, immagine 2 di 2
    • Pull out the pin and remove the scroll wheel assembly.
    • Take out the two springs under the scroll wheel assembly.
    • Be careful when lifting the scroll wheel assembly. Do not lose the two specified springs.
  7. Logitech G502 Proteus Core Cable Replacement: passo 7, immagine 1 di 1
    • Unscrew five 12.5mm screws from the motherboard.
  8. Logitech G502 Proteus Core Cable Replacement: passo 8, immagine 1 di 3 Logitech G502 Proteus Core Cable Replacement: passo 8, immagine 2 di 3 Logitech G502 Proteus Core Cable Replacement: passo 8, immagine 3 di 3
    • Open the tabs lock on each side so you can disconnect the ribbon.
    • Disconnect the PCB from the mouse cable.
  9. Logitech G502 Proteus Core Cable Replacement: passo 9, immagine 1 di 3 Logitech G502 Proteus Core Cable Replacement: passo 9, immagine 2 di 3 Logitech G502 Proteus Core Cable Replacement: passo 9, immagine 3 di 3
    • Pull out the plastic piece.
    • Remove the mouse cable.
Conclusione
Altre 7 persone hanno completato questa guida.
Sen
Membro da: 09/19/21
358 Reputazione
1 Guida realizzata
2 Commenti
Let's say you're trying to fix your G502 without a legit logitech cord, you can just splice a usb cable and solder the correct wires to the pins. I did this twice and it works flawlessly
Black.Technician - Replica
If you are careful enough, you don't need to remove the side button ribbon.
Yueh Tse Chen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 76
Ultimi 30 Giorni: 329
Tutti i Tempi: 7,193
