Salta al contenuto principale
Logitech G400s Mouse Cable Replacement
Cosa ti serve
  1. Logitech G400s Mouse Cable Replacement, Mouse Cable: passo 1, immagine 1 di 1
    • Use a Jimmy to remove the mouse feet.
    • Be careful to remove any film left by the mouse feet as well.
  2. Logitech G400s Mouse Cable Replacement: passo 2, immagine 1 di 1
    • Remove the bottom mouse foot using a Jimmy and the same technique as in Step 1.
  3. Logitech G400s Mouse Cable Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the three 5 mm Philips screws on the bottom surface.
  4. Logitech G400s Mouse Cable Replacement: passo 4, immagine 1 di 1
    • Gently pull the upper shell away from the bottom platform.
  5. Logitech G400s Mouse Cable Replacement: passo 5, immagine 1 di 1
    • This is what the G400s will look like when the top shell is taken off.
  6. Logitech G400s Mouse Cable Replacement: passo 6, immagine 1 di 2 Logitech G400s Mouse Cable Replacement: passo 6, immagine 2 di 2
    • Push the cable into its proper place inside the mouse shell.
Conclusione
Max Evans
Membro da: 09/28/16
433 Reputazione
3 Guide realizzate
USF Tampa, Team 16-7, Eyestone Fall 2016 Membro di USF Tampa, Team 16-7, Eyestone Fall 2016
USFT-EYESTONE-F16S16G7
1 Membro
9 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 40
Tutti i Tempi: 4,814
