Salta al contenuto principale
Logitech G29 Driving Force Share/Options/PS Buttons Replacement
Cosa ti serve
  1. Logitech G29 Driving Force Share/Options/PS Buttons Replacement, Share/Options/PS Buttons: passo 1, immagine 1 di 3 Logitech G29 Driving Force Share/Options/PS Buttons Replacement, Share/Options/PS Buttons: passo 1, immagine 2 di 3 Logitech G29 Driving Force Share/Options/PS Buttons Replacement, Share/Options/PS Buttons: passo 1, immagine 3 di 3
    • Remove the 6 black hex screws holding the Playstation center cap using the H 4.0 bit. These screws have an outer diameter of 8.40mm with a length of 26mm.
    • Once the center cap is removed, detach the face of the wheel from the stand. Before removing it completely, disconnect the 7 pin white cable running into the base of the wheel, and place aside.
  2. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: passo 2, immagine 1 di 1
    • Take off the 7 4.32mm diameter 8mm long silver screws holding the PCB to the black housing on the wheel using bit J0.
  3. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: passo 3, immagine 1 di 1
    • Remove Daughterboard using bit J0
    • Remove the 2 small black screws diameter 3.41mmlength 5mm from the small PCB using the J00 bit. Once the small PCB is unscrewed set the whole board aside. This will expose a black housing that all three buttons are attached to. This was removed using the same bit and screws of the same diameter.
  4. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: passo 4, immagine 1 di 1
    • A black housing that all three buttons are attached to will be seen. This was removed using the same bit and screws of the same diameter.
  5. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: passo 5, immagine 1 di 1
    • Pick up black housing using fingers (universal size) and remove.
Conclusione
Ben varner
Membro da: 11/08/23
400 Reputazione
3 Guide realizzate
IUPUI, Team 1-3, Harley Fall 2023 Membro di IUPUI, Team 1-3, Harley Fall 2023
IUPUI-HARLEY-F23S1G3
4 Membri
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 46
Tutti i Tempi: 1,041
