Salta al contenuto principale
Logitech G29 Driving Force Paddle Assembly Replacement
Cosa ti serve
  1. Logitech G29 Driving Force Paddle Assembly Replacement, Paddle Assembly: passo 1, immagine 1 di 1
    • Remove the six 32 mm hex screws from the faceplate of the steering wheel.
  2. Logitech G29 Driving Force Paddle Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the six 10 mm #00 Phillips screws from the back of the steering wheel.
    • Gently lift off the steering wheel from the hub.
  3. Logitech G29 Driving Force Paddle Assembly Replacement: passo 3, immagine 1 di 1
    • Carefully unplug the wire connector from the motherboard of the steering wheel.
  4. Logitech G29 Driving Force Paddle Assembly Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the three 30 mm screws that are behind the steering wheel.
  5. Logitech G29 Driving Force Paddle Assembly Replacement: passo 5, immagine 1 di 1
    • Gently pull the paddle assembly off from the base of the device and carefully thread the connector through the hole in the center.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 52
Ultimi 30 Giorni: 161
Tutti i Tempi: 6,833
