Salta al contenuto principale
Logitech G29 Driving Force Paddle Assembly Replacement
Cosa ti serve
  1. Logitech G29 Driving Force Paddle Assembly Replacement, Paddle Assembly: passo 1, immagine 1 di 1
    • Remove the six 32 mm hex screws from the faceplate of the steering wheel.
    Chiedi a FixBot
  2. Logitech G29 Driving Force Paddle Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the six 10 mm #00 Phillips screws from the back of the steering wheel.
    • Gently lift off the steering wheel from the hub.
    Chiedi a FixBot
  3. Logitech G29 Driving Force Paddle Assembly Replacement: passo 3, immagine 1 di 1
    • Carefully unplug the wire connector from the motherboard of the steering wheel.
    Chiedi a FixBot
  4. Logitech G29 Driving Force Paddle Assembly Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the three 30 mm screws that are behind the steering wheel.
    Chiedi a FixBot
  5. Logitech G29 Driving Force Paddle Assembly Replacement: passo 5, immagine 1 di 1
    • Gently pull the paddle assembly off from the base of the device and carefully thread the connector through the hole in the center.
    Chiedi a FixBot
Conclusione
Altre 5 persone hanno completato questa guida.
3Commenti sulla guida
Where can I buy the paddle assembly
Kevin Junghans - Rispondi Condividi
@kevinjungh90689 have you found this out ? my paddle snapped off and I need to get a new one
Fizaan Ahmed - Rispondi Condividi
@fizaanahmed Perhaps eBay?
VauWeh - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 13
Ultimi 7 giorni: 131
Ultimi 30 giorni: 528
Tutti i Tempi: 8,353
