Salta al contenuto principale
Logitech G27 Pedal Spring Replacement
Cosa ti serve
  1. Logitech G27 Pedal Spring Replacement, Pedal Spring: passo 1, immagine 1 di 1
    • Remove two screws from each pedal with a 2.5mm allen wrench.
    • The left two pedals have 30 mm screws and the right-most pedal has 16.3 mm screws.
    • Once these screws are off, take off the front faces on each pedal, they should be very easy to remove.
  2. Logitech G27 Pedal Spring Replacement: passo 2, immagine 1 di 2 Logitech G27 Pedal Spring Replacement: passo 2, immagine 2 di 2
    • Flip over the device. Now remove fourteen 15.8 mm screws from the underside of the pedal assembly with a Phillips #1 screwdriver.
    • There are two of these screws under the carpet grip, make sure you don't miss those!
    • When finished, flip over the device again so that it's in its original position.
  3. Logitech G27 Pedal Spring Replacement: passo 3, immagine 1 di 3 Logitech G27 Pedal Spring Replacement: passo 3, immagine 2 di 3 Logitech G27 Pedal Spring Replacement: passo 3, immagine 3 di 3
    • Lift the top cover of the device from the front, don't completely remove it yet though, because there are still wires connecting both halves. (NEED PICTURE)
    • Behind the left-most pedal, there are two 7.4mm screws attaching a wire to the top cover. Remove these with a Phillips #1 screwdriver and release the wires.
    • Once the wires are no longer connected to the top cover, remove the cover completely.
  4. Logitech G27 Pedal Spring Replacement: passo 4, immagine 1 di 2 Logitech G27 Pedal Spring Replacement: passo 4, immagine 2 di 2
    • Simultaneously remove the 10mm screws connecting the pedal to the red piston behind it.
    • This will take two 2.5mm allen wrenches, one for each side of the screw.
    • Once removed, the piston can rotate free of the pedal.
  5. Logitech G27 Pedal Spring Replacement: passo 5, immagine 1 di 1
    • Flip the piston away from the pedal and remove the top half of it. The spring should now be visible. (NEED PICTURE)
    • Take out the spring, and replace it with a new one.
    • Repeat steps four and five for each pedal that needs a spring replaced.
Conclusione
Altre 10 persone hanno completato questa guida.
Grant Blake
Membro da: 04/21/15
1.761 Reputazione
2 Guide realizzate
Cal Poly, Team 15-4, Amido Spring 2015 Membro di Cal Poly, Team 15-4, Amido Spring 2015
CPSU-AMIDO-S15S15G4
4 Membri
25 Guide realizzate
6Commenti sulla guida
Is it possible to replace / renew the potentiometers used for gas / brake?
Dave Pawson - Replica
I replaced the springs and reassembled in reverse order. However, my wheel will no longer power on. Any idea where I would have lost power? Thank you.
matthew.liam.gleason - Replica
What size is the cluch spring
isaacjohnson138 - Replica
6cm length
2cm diameter
hermimaier -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 119
Tutti i Tempi: 22,115
