Salta al contenuto principale
Logitech G1 Optical Mouse Scroll Wheel Replacement
Cosa ti serve
  1. Logitech G1 Optical Mouse Scroll Wheel Replacement, Scroll Wheel: passo 1, immagine 1 di 1
    • Remove one screw at the bottom of the mouse.
  2. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 2, immagine 1 di 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 2, immagine 2 di 2
    • Pull the top of the mouse lid gently to separate it from the rest of the mouse.
    • Potential for device damage: The lid and the body are connected with a wire, so separate them gently.
  3. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 3, immagine 1 di 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 3, immagine 2 di 2
    • Pull the white connector from the circuit board.
    • Be sure the two small holes in the connector are positioned at the top when reassembling.
  4. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 4, immagine 1 di 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 4, immagine 2 di 2
    • Carefully pull the scroll wheel up.
    • The long parts of the spring should be in the southeast and southwest directions when reassembling.
  5. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 5, immagine 1 di 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 5, immagine 2 di 2
    • Carefully remove the two Phillips #0 screws.
  6. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 6, immagine 1 di 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 6, immagine 2 di 2
    • Clean the mouse case, lid, and module with a dry cotton swab or soft brush.
    • Potential for device damage: Do not use water or an iron brush to clean it.
  7. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 7, immagine 1 di 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 7, immagine 2 di 2
    • Place the new scroll wheel into the mouse.
  8. Logitech G1 Optical Mouse Scroll Wheel Replacement: passo 8, immagine 1 di 1
    • The spring should be inserted into a small groove.
    • The spring can be inserted after combining the mouse body.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 31
Tutti i Tempi: 2,018
