Introduzione
Over time, the mode switch on your Logitech G X56 HOTAS Throttle may become unresponsive or unreliable due to wear, corrosion, or internal failure. If you're experiencing issues with switching modes or the dial is no longer registering inputs correctly, the mode switch likely needs replacement. This guide will walk you through the necessary steps to safely replace the mode switch and restore full functionality.
Cosa ti serve
Use an 11 mm deep socket to remove the nut from the post of the switch.
