Introduzione
The top buttons and the trigger are typically the most used, meaning the dip switches could become the first to be worn. This will require replacement for full use of the joystick.
Cosa ti serve
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
Remove the three 7mm Phillips #1 screws from the button board.
Remove the button board from the plastic top.
Altre 4 persone hanno completato questa guida.
