Salta al contenuto principale
Logitech Extreme 3D Pro Disassembly of the handle
Cosa ti serve
  1. Logitech Extreme 3D Pro Disassembly of the handle, Disassembly of the handle: passo 1, immagine 1 di 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Disassembly of the handle: passo 2, immagine 1 di 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Disassembly of the handle: passo 3, immagine 1 di 2 Logitech Extreme 3D Pro Disassembly of the handle: passo 3, immagine 2 di 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
Conclusione
Altre 6 persone hanno completato questa guida.
Emanuel Canela
Membro da: 01/25/18
1.369 Reputazione
7 Guide realizzate
USF Tampa, Team S7-G1, Passmore Spring 2018 Membro di USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Membri
7 Guide realizzate
3Commenti sulla guida
yeah but i got this far before looking at the site, and what i really want to see is how the cotter ring pin is set on the shaft that enables the z-rot instead of locking it down.
erock steady - Replica
if you havent worked it out already, the Z-rot spring needs spread across a little 3/8 inch tab, otherwise it will lock the axis a few degrees off center
cody Werdal -
reassembling is tricky. The spring tabs for z-rot need to be aligned on one side of the handle and the z-rot potentiometer needs aligning on the other. There is nothing obvious in the handle design to guide the correct positioning. The difficult part is getting the pot tab to stay in its slot. If anyone knows of a technique to assist getting the handles halves and pot in the correct alignment, please do tell.
memar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 49
Tutti i Tempi: 4,418
