Salta al contenuto principale
Logitech Extreme 3D Pro Disassembly of the base
Cosa ti serve
  1. Logitech Extreme 3D Pro Disassembly of the base, Disassembly of the handle: passo 1, immagine 1 di 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Disassembly of the base: passo 2, immagine 1 di 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Disassembly of the base: passo 3, immagine 1 di 2 Logitech Extreme 3D Pro Disassembly of the base: passo 3, immagine 2 di 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Disassembly of the base, Disassembly of the base: passo 4, immagine 1 di 1
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro Disassembly of the base: passo 5, immagine 1 di 3 Logitech Extreme 3D Pro Disassembly of the base: passo 5, immagine 2 di 3 Logitech Extreme 3D Pro Disassembly of the base: passo 5, immagine 3 di 3
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
Conclusione
Altre 3 persone hanno completato questa guida.
Emanuel Canela
Membro da: 01/25/18
1.369 Reputazione
7 Guide realizzate
USF Tampa, Team S7-G1, Passmore Spring 2018 Membro di USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Membri
7 Guide realizzate
2Commenti sulla guida
And you didn’t even finish the repair. Thanks for nothing. :(
Jesse James - Replica
Thank you very much
Claude1864 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 99
Tutti i Tempi: 5,274
