Introduzione
If your buttons are sticking and they cannot be cleaned from the outside, here is how you can clean it from the inside.
Cosa ti serve
To get into the controller, you will need to unscrew the 7 screws on the back.
You will have to remove the bottom oval sticker to reveal the screw circled in orange.
With the screws removed, turn the controller upside down. Insert the iFixit opening tool between the top and bottom casing to pry them apart.
Separate the top and bottom casing.
It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
There should be the four circular buttons labeled 1-4, four smaller circular buttons for the D-Pad, and three rounded rectangular buttons.
Turn the top casing of the controller over to remove all the buttons.
Wipe each individual button with a piece of cloth and rubbing alcohol.
Altre 10 persone hanno completato questa guida.
Un commento
What is the right side of dpad buttons when put back?
There a polish side and another with fabric numbers. What side have to be up and down?
