Salta al contenuto principale
Logitech Dual Action disassembly
Cosa ti serve
  1. Logitech Dual Action disassembly, Taking out the screws: passo 1, immagine 1 di 1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in orange.
  2. Logitech Dual Action disassembly, Opening the controller: passo 2, immagine 1 di 3 Logitech Dual Action disassembly, Opening the controller: passo 2, immagine 2 di 3 Logitech Dual Action disassembly, Opening the controller: passo 2, immagine 3 di 3
    • With the screws removed, turn the controller upside down. Insert the iFixit opening tool between the top and bottom casing to pry them apart.
    • Separate the top and bottom casing.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the four circular buttons labeled 1-4, four smaller circular buttons for the D-Pad, and three rounded rectangular buttons.
  3. Logitech Dual Action disassembly, Cleaning the buttons: passo 3, immagine 1 di 1
    • Turn the top casing of the controller over to remove all the buttons.
    • Wipe each individual button with a piece of cloth and rubbing alcohol.
Linea Traguardo
Altre 10 persone hanno completato questa guida.
Brian Neuman
Membro da: 01/20/15
908 Reputazione
3 Guide realizzate
USF Tampa, Team 7-4, Remmell Winter 2015 Membro di USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Membri
3 Guide realizzate
Un commento
What is the right side of dpad buttons when put back?
There a polish side and another with fabric numbers. What side have to be up and down?
rodrigomarshmallow - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 112
Tutti i Tempi: 6,242
