Salta al contenuto principale
Logitech Dual Action Triggers Repair
Cosa ti serve
  1. Logitech Dual Action Triggers Repair, Logitech Dual Action Triggers Repair: passo 1, immagine 1 di 1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in red.
  2. Logitech Dual Action Triggers Repair: passo 2, immagine 1 di 2 Logitech Dual Action Triggers Repair: passo 2, immagine 2 di 2
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
  3. Logitech Dual Action Triggers Repair: passo 3, immagine 1 di 1
    • There should be 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 oval shaped buttons.
  4. Logitech Dual Action Triggers Repair: passo 4, immagine 1 di 3 Logitech Dual Action Triggers Repair: passo 4, immagine 2 di 3 Logitech Dual Action Triggers Repair: passo 4, immagine 3 di 3
    • In the center of the controller, pull upwards on the USB cord.
    • Be careful not to pull hard enough to yank the wires connecting to the logic board.
    • With the wire out of the way, remove the screw it exposed. This will disconnect the logic board from the controller.
  5. Logitech Dual Action Triggers Repair: passo 5, immagine 1 di 3 Logitech Dual Action Triggers Repair: passo 5, immagine 2 di 3 Logitech Dual Action Triggers Repair: passo 5, immagine 3 di 3
    • To remove the triggers, push upwards from the back on them.
    • Once far enough, detach the logic board from the back cover piece and the triggers.
  6. Logitech Dual Action Triggers Repair: passo 6, immagine 1 di 2 Logitech Dual Action Triggers Repair: passo 6, immagine 2 di 2
    • If the wire is unplugged solely from the logic board, you can fasten it back into its place.
    • Look at the second picture to see where the wires go.
  7. Logitech Dual Action Triggers Repair: passo 7, immagine 1 di 3 Logitech Dual Action Triggers Repair: passo 7, immagine 2 di 3 Logitech Dual Action Triggers Repair: passo 7, immagine 3 di 3
    • Unscrew the screw on the trigger to remove the back cover.
    • Once removed, carefully pull the back cover off.
  8. Logitech Dual Action Triggers Repair: passo 8, immagine 1 di 1
    • The 3 wires are soldered into the 3 spots circled on the picture.
    • You can now fasten the wire into the right spot on the trigger piece.
Conclusione
Altre 4 persone hanno completato questa guida.
Brian Neuman
Membro da: 01/20/15
923 Reputazione
3 Guide realizzate
USF Tampa, Team 7-4, Remmell Winter 2015 Membro di USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Membri
3 Guide realizzate
2 Commenti
Hi dear, can you say me the order of colours in the USB cable? I think green, white, red, black thin and black thick. Is It correct?
Cas - Replica
Where can I get conductive pads for this?
Ginga - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 50
Ultimi 30 Giorni: 206
Tutti i Tempi: 9,540
