Salta al contenuto principale
Logitech Circle Speaker Replacement
Cosa ti serve
  1. Logitech Circle Speaker Replacement, Speaker: passo 1, immagine 1 di 2 Logitech Circle Speaker Replacement, Speaker: passo 1, immagine 2 di 2
    • Wedge the plastic opening tool under the black circle lens to gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
  2. Logitech Circle Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
  3. Logitech Circle Speaker Replacement: passo 3, immagine 1 di 2 Logitech Circle Speaker Replacement: passo 3, immagine 2 di 2
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
  4. Logitech Circle Speaker Replacement: passo 4, immagine 1 di 2 Logitech Circle Speaker Replacement: passo 4, immagine 2 di 2
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
  5. Logitech Circle Speaker Replacement: passo 5, immagine 1 di 2 Logitech Circle Speaker Replacement: passo 5, immagine 2 di 2
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
  6. Logitech Circle Speaker Replacement: passo 6, immagine 1 di 2 Logitech Circle Speaker Replacement: passo 6, immagine 2 di 2
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
  7. Logitech Circle Speaker Replacement: passo 7, immagine 1 di 1
    • Locate the speaker attachment, and carefully remove the speaker plug from the lens.
  8. Logitech Circle Speaker Replacement: passo 8, immagine 1 di 1
    • Remove the speaker using a plastic opening tool. The battery is attached with glue, so use gentle prying motions to remove speaker.
Conclusione
Emma Cochran
Membro da: 09/28/17
110 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 386
