Salta al contenuto principale
Lite-On LightScribe SHM-165H6S Disc Tray Replacement
Cosa ti serve
  1. Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Chassis: passo 1, immagine 1 di 2 Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Chassis: passo 1, immagine 2 di 2
    • Insert an open paper clip into the small hole on the left side of the faceplate.
    • After the tray opens, extend it fully.
  2. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 2, immagine 1 di 3 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 2, immagine 2 di 3 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 2, immagine 3 di 3
    • Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
  3. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 3, immagine 1 di 1
    • Pull the faceplate away from the main chassis.
  4. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 4, immagine 1 di 1
    • Unscrew the four 8.5 mm screws on the bottom chassis using a Philips #2 screwdriver.
  5. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 5, immagine 1 di 2 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 5, immagine 2 di 2
    • Lift the top and bottom chassis straight up in order to remove them.
  6. Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Disc Tray: passo 6, immagine 1 di 3 Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Disc Tray: passo 6, immagine 2 di 3 Lite-On LightScribe SHM-165H6S Disc Tray Replacement, Disc Tray: passo 6, immagine 3 di 3
    • Extend the tray fully.
    • Push the tab on the right side to the left.
    • Push the tab on the left side to the left.
    • Remove the tray carefully.
  7. Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 7, immagine 1 di 3 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 7, immagine 2 di 3 Lite-On LightScribe SHM-165H6S Disc Tray Replacement: passo 7, immagine 3 di 3
    • Guide the replacement tray under the beige tabs.
    • Make sure the grey piece is slid to the right, so the grey nob is under the right-hand groove of the tray.
    • Check to see that the tray extends and closes smoothly.
Conclusione
Cal Poly, Team 6-5, Regan Fall 2011 Membro di Cal Poly, Team 6-5, Regan Fall 2011
CPSU-REGAN-F11S6G5
2 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 4,270
