Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Will your groovy disco ball not turn on? This guide will teach you to remove and replace the switch so you can get back to your partying.
  1. Unplug the device to avoid injury. Use a Phillips head screwdriver to unscrew the single screw.
    • Unplug the device to avoid injury.
    • Use a Phillips head screwdriver to unscrew the single screw.
    • Hold on to the nut from the other side so you do not lose it.
    • Remove the panel that conceals the switch.
  2. Hold on to the red disc with needle nosed pliers, and use the Phillips head screwdriver to remove the disc by pushing down.
    • Hold on to the red disc with needle nosed pliers, and use the Phillips head screwdriver to remove the disc by pushing down.
  3. Remove and replace the white switch. Do not be afraid to pull as this takes a bit of force to remove.
    • Remove and replace the white switch.
    • Do not be afraid to pull as this takes a bit of force to remove.
Conclusione
Courtney Elliott
Membro da: 14/01/2014
366 Reputazione
3 Guide realizzate
Cal Poly, Team 17-3, Forte Winter 2014 Membro di Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 565
