Salta al contenuto principale
Introduzione
Has your disco ball stopped rotating and turned into a weird, multi-colored lamp? Use this guide to avoid the party-foul and get that ball spinning!
Parti
  1. Turn the device over so that the base is on top.
    • Turn the device over so that the base is on top.
  2. Peel off the piece of metal that is glued to hold the two halves of the base together.
    • Peel off the piece of metal that is glued to hold the two halves of the base together.
    • You may need rubber cement to reapply the piece of metal when reassembling the device.
  3. Unscrew the four 10mm Phillips head screws on the bottom of the device. Once the base is removed, the device should look as shown on the picture.
    • Unscrew the four 10mm Phillips head screws on the bottom of the device.
    • Once the base is removed, the device should look as shown on the picture.
  4. Use a pair of tweezers to crush the sides of the wirenuts. The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
    • Use a pair of tweezers to crush the sides of the wirenuts.
    • The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
    • Pull all of the wires out of the wirenuts.
  5. Separate the wires that belong to the motor. The wires should be small and black.
    • Separate the wires that belong to the motor.
    • The wires should be small and black.
    • Remove the motor.
Conclusione
To reassemble your device, follow these instructions in reverse order, starting from step five.
Courtney Elliott
Membro da: 14/01/2014
366 Reputazione
3 Guide realizzate
Cal Poly, Team 17-3, Forte Winter 2014 Membro di Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Membri
7 Guide realizzate
Where can you find a replacement motor?
bellyjb - Replica
I can't find one either!!!!
Dallin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,003
