Salta al contenuto principale
Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement
Cosa ti serve
  1. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Lite FX Rotating Big Ball of Lite Model 1929 Ball Disassembly: passo 1, immagine 1 di 1
    • Unplug the device to avoid injury.
    • Turn the device over, so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: passo 2, immagine 1 di 3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: passo 2, immagine 2 di 3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: passo 2, immagine 3 di 3
    • Compress the tab by pushing towards the center of the device with a spudger.
    • While compressing the tab, peel the base away from the rotating head.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: passo 3, immagine 1 di 1
    • If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
  4. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: passo 4, immagine 1 di 3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: passo 4, immagine 2 di 3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: passo 4, immagine 3 di 3
    • Push the color panel by applying pressure from the inside while twisting to line up the tabs with the notches.
    • Insert a new color panel by pushing it into place while lining up the tabs with the notches.
Conclusione
Cal Poly, Team 17-3, Forte Winter 2014 Membro di Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 636
