Salta al contenuto principale
Linsay Model F-7HD2CORE Battery Replacement
Cosa ti serve
  1. Linsay Model F-7HD2CORE Battery Replacement, Battery: passo 1, immagine 1 di 3 Linsay Model F-7HD2CORE Battery Replacement, Battery: passo 1, immagine 2 di 3 Linsay Model F-7HD2CORE Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Carefully insert your plastic opening tool in between the white and black sections of your device.
    • Gently pry the top screen portion from the base of the tablet.
    • Your tablet should now look like the third image.
  2. Linsay Model F-7HD2CORE Battery Replacement: passo 2, immagine 1 di 2 Linsay Model F-7HD2CORE Battery Replacement: passo 2, immagine 2 di 2
    • To completely remove the base from the top of the tablet, peel the microphone from the back.
  3. Linsay Model F-7HD2CORE Battery Replacement: passo 3, immagine 1 di 2 Linsay Model F-7HD2CORE Battery Replacement: passo 3, immagine 2 di 2
    • Remove the two pieces of tape holding the battery in place by gently peeling it off.
  4. Linsay Model F-7HD2CORE Battery Replacement: passo 4, immagine 1 di 1
    • Using the spudger, carefully peel the battery off of the tablet panel.
    • Tape of the back of the battery will be very strong, pull gently!
    • The metal exterior of the battery can be quite pliable. Use caution when removing the battery from the tablet.
  5. Linsay Model F-7HD2CORE Battery Replacement: passo 5, immagine 1 di 1
    • To remove the battery, completely desolder the wires connected to the circuit board.
    • To reattach the new battery, you must solder the wires back on.
Conclusione
Altre 2 persone hanno completato questa guida.
Penn State, Team 1-5, Kaschak Winter 2015 Membro di Penn State, Team 1-5, Kaschak Winter 2015
PSU-KASCHAK-W15S1G5
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,443
