Salta al contenuto principale
Linksys e1200 Wireless Router Ethernet Port Replacement
Cosa ti serve
  1. Linksys e1200 Wireless Router Ethernet Port Replacement, Ethernet Port: passo 1, immagine 1 di 3 Linksys e1200 Wireless Router Ethernet Port Replacement, Ethernet Port: passo 1, immagine 2 di 3 Linksys e1200 Wireless Router Ethernet Port Replacement, Ethernet Port: passo 1, immagine 3 di 3
    • The PC board is loosely attached to the plastic base. Note the micro-soldered terminals on the Ethernet ports. These are very small and require significant expertise to desolder and replace.
  2. Linksys e1200 Wireless Router Ethernet Port Replacement: passo 2, immagine 1 di 1
    • Do to modern manufacturing, you will need to cover the area in solder flux; it is messy, so be careful.
    • Prep your desoldering braid by pulling it into a shape that will allow it to contact the solder on the baord itself.
    • Touch the soldering iron to the top of the contact after it has heated sufficiently; the flux will melt, as will the solder, and both should flow into the desoldering braid.
  3. Linksys e1200 Wireless Router Ethernet Port Replacement: passo 3, immagine 1 di 2 Linksys e1200 Wireless Router Ethernet Port Replacement: passo 3, immagine 2 di 2
    • After removing all of the solder from each terminal, you may try pushing out the ethernet port. If it won't go, you need to remove more solder.
    • If neccessary, you will need to make a custom tool to touch all of the contacts at once. This one is made of bent copper wire and can replace the tip on a pencil-style soldering iron.
    • Once the ethernet port is removed, you may replace it (or anything else you had to remove), and solder it to the circuit board.
    • You can find many fine soldering guides online, here is a reccommended one: http://www.wikihow.com/Solder-%28Electro... Remember to add flux to the joint prior to soldering.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,825
