Salta al contenuto principale
Linksys WRT54GS v2 Motherboard Replacement
Cosa ti serve
  1. Linksys WRT54GS v2 Motherboard Replacement, Front Case: passo 1, immagine 1 di 1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Motherboard Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Motherboard Replacement: passo 4, immagine 1 di 1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  5. Linksys WRT54GS v2 Motherboard Replacement, Motherboard: passo 5, immagine 1 di 1
    • Slide the board unit out and up.
  6. Linksys WRT54GS v2 Motherboard Replacement: passo 6, immagine 1 di 1
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
Conclusione
Altre 2 persone hanno completato questa guida.
Allian Roman
Membro da: 10/12/11
276 Reputazione
5 Guide realizzate
Cal Poly, Team 3-4, Regan Fall 2011 Membro di Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,849
