Salta al contenuto principale
Linksys WRT54GS v2 Front Case Replacement
Cosa ti serve
  1. Linksys WRT54GS v2 Front Case Replacement, Front Case: passo 1, immagine 1 di 1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Front Case Replacement: passo 2, immagine 1 di 1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Front Case Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Front Case Replacement: passo 4, immagine 1 di 1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
Conclusione
Allian Roman
Membro da: 10/12/11
276 Reputazione
5 Guide realizzate
Cal Poly, Team 3-4, Regan Fall 2011 Membro di Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,119
