Salta al contenuto principale
Linksys WAP54g Antennas Replacement
  1. Linksys WAP54g Antennas Replacement, Antennas: passo 1, immagine 1 di 2 Linksys WAP54g Antennas Replacement, Antennas: passo 1, immagine 2 di 2
    • Make sure the antennas are in a straight position, not bent, to remove the black casing.
    • Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
  2. Linksys WAP54g Antennas Replacement: passo 2, immagine 1 di 1
    • Grip antenna at the base and twist counter-clockwise to unscrew it from the device. The base should have a rough feel to it.
  3. Linksys WAP54g Antennas Replacement: passo 3, immagine 1 di 1
    • Once antenna is completely detached, obtain the new antenna, and place it on device so the threads line up.
  4. Linksys WAP54g Antennas Replacement: passo 4, immagine 1 di 1
    • Screw antenna onto device by twisting the base of the antenna in a clockwise motion until it is tight and does not turn any further.
  5. Linksys WAP54g Antennas Replacement: passo 5, immagine 1 di 1
    • Place the black casing, which was removed in step 1, back onto the base of the antenna to cover up exposed metal.
    • Repeat these steps for other antenna.
Conclusione
After the repairs are made the device should working.
Altre 2 persone hanno completato questa guida.
Derek Myers
Membro da: 10/04/11
288 Reputazione
5 Guide realizzate
Cal Poly, Team 21-21, Maness Fall 2011 Membro di Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,598
