Salta al contenuto principale
Linear Rail V2/V3 Endstop Install
Cosa ti serve
  1. Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: passo 1, immagine 1 di 3 Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: passo 1, immagine 2 di 3 Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: passo 1, immagine 3 di 3
    • M3 Sliding T-Nut
    • Slide in the M3 T-Nut toward the middle of the printer
    • M3X12 BHCS & M3 FLAT WASHERS
    • M3x10 FHCS
    • Adjustable Endstop Mount A
    • Adjustable Endstop Mount B
    • Tighten the M3 screw into the T-Nut
  2. Linear Rail V2/V3 Endstop Install, Endstop install: passo 2, immagine 1 di 2 Linear Rail V2/V3 Endstop Install, Endstop install: passo 2, immagine 2 di 2
    • Adjust endstop mount until it is square with the Linear rail
    • Remove stock endstop board form Creality mount and Reuse the stock screws to mount the endstop as shown
  3. Linear Rail V2/V3 Endstop Install, Setting endstop position: passo 3, immagine 1 di 2 Linear Rail V2/V3 Endstop Install, Setting endstop position: passo 3, immagine 2 di 2
    • Use M3x12 BHCS to adjust the endstop position, so the nozzle tip is even with the front edge of the bed when the end stop is triggered
    • Check the clearance between the motor and the linear adaptor. When the bed is all the way back against the endstop. There should be a 1-2 mm gap when the endstop is triggered.
Conclusione
AJ Pereira
Membro da: 05/29/20
2.735 Reputazione
16 Guide realizzate
Tiny Machines 3D Membro di Tiny Machines 3D
Community
5 Membri
41 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 74
Tutti i Tempi: 1,874
