Salta al contenuto principale
Lightahead DV328 Arrow Button Replacement
Cosa ti serve
  1. Lightahead DV328 Arrow Button Replacement, Arrow Button: passo 1, immagine 1 di 3 Lightahead DV328 Arrow Button Replacement, Arrow Button: passo 1, immagine 2 di 3 Lightahead DV328 Arrow Button Replacement, Arrow Button: passo 1, immagine 3 di 3
    • Use a spudger to remove the two screw covers.
    • Remove the two Phillips #0 screws.
  2. Lightahead DV328 Arrow Button Replacement: passo 2, immagine 1 di 3 Lightahead DV328 Arrow Button Replacement: passo 2, immagine 2 di 3 Lightahead DV328 Arrow Button Replacement: passo 2, immagine 3 di 3
    • Once you are able to lift the cover up, you will then be able to pry off the lens which will allow for the device to open more.
    • Take off the lens cover. Be careful not to pull the device open too much otherwise you will snap it in half since it is made of plastic.
    • Once you have this up, pull up the cover and you will now be able to work on the arrow key button
  3. Lightahead DV328 Arrow Button Replacement: passo 3, immagine 1 di 3 Lightahead DV328 Arrow Button Replacement: passo 3, immagine 2 di 3 Lightahead DV328 Arrow Button Replacement: passo 3, immagine 3 di 3
    • Lay the camcorder on its side. The arrow key button is now in full view.
    • There is a small green piece locking in the arrow key button. Once you remove that, the piece will be able to come out.
    • Gently push on the button and it will come out of the device. Replace as needed
Conclusione
USF Tampa, Team 10-2, Remmell Spring 2016 Membro di USF Tampa, Team 10-2, Remmell Spring 2016
USFT-REMMELL-S16S10G2
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 172
