Salta al contenuto principale
Light and Motion SOLA VIDEO2000 battery Replacement
Cosa ti serve
  1. Light and Motion SOLA VIDEO2000  battery Replacement, Unscrew the light head cap: passo 1, immagine 1 di 2 Light and Motion SOLA VIDEO2000  battery Replacement, Unscrew the light head cap: passo 1, immagine 2 di 2
    • This step may need some force applied to unscrew the lamp head cap.
  2. Light and Motion SOLA VIDEO2000  battery Replacement, Remove the light head: passo 2, immagine 1 di 2 Light and Motion SOLA VIDEO2000  battery Replacement, Remove the light head: passo 2, immagine 2 di 2
    • Gently pull the light head by the PCB, not the plastic cover
    • Take note how the light head connector is guided to the PCB connector, all through the plastic cover guide.
  3. Light and Motion SOLA VIDEO2000  battery Replacement, Remove the cover guide: passo 3, immagine 1 di 2 Light and Motion SOLA VIDEO2000  battery Replacement, Remove the cover guide: passo 3, immagine 2 di 2
    • Gently remove the plastic cover guide
    • Take note of the cable management. It will ease the reassembly
  4. Light and Motion SOLA VIDEO2000  battery Replacement, Remove the PCB and battery assembly: passo 4, immagine 1 di 2 Light and Motion SOLA VIDEO2000  battery Replacement, Remove the PCB and battery assembly: passo 4, immagine 2 di 2
    • Gently shake the lamp and let the battery and PCB slide in your hand
    • Take note of the location where the PCB will have to slide-in during reassembly
  5. Light and Motion SOLA VIDEO2000  battery Replacement, Remove the O-ring: passo 5, immagine 1 di 2 Light and Motion SOLA VIDEO2000  battery Replacement, Remove the O-ring: passo 5, immagine 2 di 2
    • Gently remove the o-ring, clean it and apply o-ring grease
    • Clean the o-ring seats, both on the body and the metallic cap.
  6. Light and Motion SOLA VIDEO2000  battery Replacement, Disconnect the battery: passo 6, immagine 1 di 2 Light and Motion SOLA VIDEO2000  battery Replacement, Disconnect the battery: passo 6, immagine 2 di 2
    • Gently disconnect the battery from the PCB
    • Avoid touching the metallic strips (humidity sensor, to detect flooding) If it happens, gently wipe it with a dry, non abrasive, cloth
    • Connect the new battery
Conclusione
Use some force to screw back the lamp head cap, but not too much!
After 3 full discharge cycles, the higher capacity battery will give 65min light at full brightness (vs 45 min with the original battery)
Altre 4 persone hanno completato questa guida.
ralf
Membro da: 06/28/13
363 Reputazione
2 Guide realizzate
3Commenti sulla guida
Bonjour,
Le pack de batteries est cher pour 2 18650.
Y a t il un moyen de faire autrement ?
jpdupin - Replica
C'est pas faux, mais les packs d'accus sont généralement appairés par pièces aux caractéristiques aussi semblables que possible.
Il faut sinon démonter le pack d'origine, et récupérer le PCB... cela demande plus d'outillage et de matériel, et il faudra prendre garde à commander des accus avec languettes à souder (à moins de disposer d'un poste de soudure par points).
Pour qui a le temps et les compétences, ça peut effectivement valoir la peine...
ralf - Replica
Do these batteries also work for the Sola Dive light 800?
Hruijs - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 101
Tutti i Tempi: 4,269
