Salta al contenuto principale
Lezyne CNC Dirt Floor Drive Gauge Replacement
Cosa ti serve
  1. Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Cover: passo 1, immagine 1 di 2 Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Cover: passo 1, immagine 2 di 2
    • Using a flat head screwdriver, pry up an edge of the gauge cover.
    • Remove the gauge cover.
  2. Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Face Plate and Internals: passo 2, immagine 1 di 2 Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Face Plate and Internals: passo 2, immagine 2 di 2
    • No parts from the old gauge will be re-used, so there is no need to attempt to preserve the parts. However, be careful not to damage the gauge housing.
    • Pry up a corner of the gauge face plate.
    • Use pliers to pull off the gauge face plate.
    • Be careful when prying off the face plate, as the edges are sharp.
    • Use pliers to remove the internal gauge mechanics.
  3. Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Old Gauge: passo 3, immagine 1 di 2 Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Old Gauge: passo 3, immagine 2 di 2
    • Using pliers, grip the exposed brass piece and unthread the gauge by rotating the gauge counter-clockwise.
    • Pull the gauge out of its housing.
  4. Lezyne CNC Dirt Floor Drive Gauge Replacement, Replacing the Gauge O-rings: passo 4, immagine 1 di 2 Lezyne CNC Dirt Floor Drive Gauge Replacement, Replacing the Gauge O-rings: passo 4, immagine 2 di 2
    • Remove the O-ring that is at the bottom of the threaded hole that the gauge threaded into.
    • Place a new O-ring into the hole.
  5. Lezyne CNC Dirt Floor Drive Gauge Replacement, Applying Threadlocker: passo 5, immagine 1 di 1
    • Apply medium-strength Loctite (green, 290) to the threads of the new gauge.
  6. Lezyne CNC Dirt Floor Drive Gauge Replacement, Installing the New Gauge: passo 6, immagine 1 di 3 Lezyne CNC Dirt Floor Drive Gauge Replacement, Installing the New Gauge: passo 6, immagine 2 di 3 Lezyne CNC Dirt Floor Drive Gauge Replacement, Installing the New Gauge: passo 6, immagine 3 di 3
    • Thread the new gauge into the floor pump by turning it clockwise in its housing.
    • Thread the gauge until it is snug and the BAR/psi markings are aligned with the pump body.
    • Gauge performance will not be affected by its position, so long as it is snug.
    • Allow at least 30 minutes for the thread locker to set.
    • Test pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it.
Linea Traguardo
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
7 Commenti
i use both gold and silver bracelets because for me, they are both great bracelets to wear;; <a href="https://www.chinamaijin.com/">cnc machining</a>
saif 77 - Replica
Its good  as your other  content  : D,  appreciate it for posting . <a href="https://www.chinamaijin.com/">cnc machining parts</a>
saif 77 - Replica
I feel nice about it and love learning more about this topic. <a href="https://certifiedbourbon.com/product/blu...">blue label for sale</a> I will come to your site to find out more and tell my acquaintances about you.
Biplob Chandra Singha - Replica
Nice information and good tips for SEO off-page optimization. I have got good tips to improve SEO off-page Optimization. Thanks for sharing! <a href="https://certifiedbourbon.com/product/pap...>pappy van winkle online</a> please keep it up Maintains!
legalweed suppliers - Replica
I was checking continuously this list and I’m impressed! Extremely useful info especially this blog commenting sites list. <a href="https://mushroomlux.com/product/dmt-cart...>purecybin dmt</a> Thank you and best of luck.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 26
Tutti i Tempi: 5,491
