Salta al contenuto principale
Lexmark Intuition S505 Ink Cartridges Replacement
  1. Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: passo 1, immagine 1 di 2 Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: passo 1, immagine 2 di 2
    • Lift the scanning unit, exposing the print head.
  2. Lexmark Intuition S505 Ink Cartridges Replacement: passo 2, immagine 1 di 1
    • Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
  3. Lexmark Intuition S505 Ink Cartridges Replacement: passo 3, immagine 1 di 1
    • Lift the frame to expose the ink cartridges.
  4. Lexmark Intuition S505 Ink Cartridges Replacement: passo 4, immagine 1 di 1
    • Push the button located above the designated ink cartridge until it pops out.
  5. Lexmark Intuition S505 Ink Cartridges Replacement: passo 5, immagine 1 di 1
    • Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
  6. Lexmark Intuition S505 Ink Cartridges Replacement: passo 6, immagine 1 di 2 Lexmark Intuition S505 Ink Cartridges Replacement: passo 6, immagine 2 di 2
    • Close the scanner unit.
Conclusione
Once your ink cartridges are in place, your printer should now print high-quality documents.
Altre 2 persone hanno completato questa guida.
Omar
Membro da: 01/23/13
111 Reputazione
2 Guide realizzate
Cal Poly, Team 18-38, Regan Winter 2013 Membro di Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Membri
8 Guide realizzate
Un commento
Hello there, thanks for your demonstration. In case that the cartridges are not genuine (not a lexmark brand), will the printer will be able to print?
I own this model. Thanks in advance!
Dimitri Sideris - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 3,270
