Salta al contenuto principale
Levoit Vital 100 HEPA Filter Replacement
Cosa ti serve
  1. Levoit Vital 100 HEPA Filter Replacement, Filter: passo 1, immagine 1 di 2 Levoit Vital 100 HEPA Filter Replacement, Filter: passo 1, immagine 2 di 2
    • Unplug the air purifier and remove the cover by pulling the side handle away from machine.
  2. Levoit Vital 100 HEPA Filter Replacement: passo 2, immagine 1 di 1
    • Remove the old air filter by pulling the looped, white tab towards yourself.
    • This comes out without resistance and there are no hooked attachments.
  3. Levoit Vital 100 HEPA Filter Replacement: passo 3, immagine 1 di 1
    • Clean out any remaining dust and hair inside purifier using a vacuum or towel.
  4. Levoit Vital 100 HEPA Filter Replacement: passo 4, immagine 1 di 1
    • Unwrap the new filter and place it inside the air purifier with the tabs at the top and facing outward.
    • The filter should fit in snugly as there are no attachments surrounding the fitting.
  5. Levoit Vital 100 HEPA Filter Replacement: passo 5, immagine 1 di 2 Levoit Vital 100 HEPA Filter Replacement: passo 5, immagine 2 di 2
    • Make sure air purifier cover is fitted properly by sinking the two legs into the holes shown at the arrows in photo one and then replacing the filter cover on the front by simply pushing it forward.
    • The air purifier will not power on unless the filter cover is replaced correctly.
  6. Levoit Vital 100 HEPA Filter Replacement: passo 6, immagine 1 di 1
    • After plugging the air purifier back in, reset the Check Filter Indicator by pressing the filter icon at the top and holding it for 3 seconds.
Conclusione
Enjoy the fresh air!
Cody B
Membro da: 03/04/23
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 60
Tutti i Tempi: 1,519
