Salta al contenuto principale
Les Paul Wireless Guitar Strummer Replacement
Cosa ti serve
  1. Les Paul Wireless Guitar Strummer Replacement, Les Paul Wireless Guitar Body Teardown: passo 1, immagine 1 di 1
    • Remove batteries
  2. Les Paul Wireless Guitar Strummer Replacement: passo 2, immagine 1 di 2 Les Paul Wireless Guitar Strummer Replacement: passo 2, immagine 2 di 2
    • Remove void warranty sticker
    • The sticker is covering a torx screw
  3. Les Paul Wireless Guitar Strummer Replacement: passo 3, immagine 1 di 3 Les Paul Wireless Guitar Strummer Replacement: passo 3, immagine 2 di 3 Les Paul Wireless Guitar Strummer Replacement: passo 3, immagine 3 di 3
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  4. Les Paul Wireless Guitar Strummer Replacement, Strummer: passo 4, immagine 1 di 2 Les Paul Wireless Guitar Strummer Replacement, Strummer: passo 4, immagine 2 di 2
    • Remove the 4 screws from the back of the strum chip using a Phillips PH1 screwdriver. each of these screws are 1.2 cm each.
    • Remove the 4 inner screws, each are 0.8 cm.
    • Make sure that when putting back together, the 4 inner screws line up with the small plastic piece underneath.
  5. Les Paul Wireless Guitar Strummer Replacement: passo 5, immagine 1 di 3 Les Paul Wireless Guitar Strummer Replacement: passo 5, immagine 2 di 3 Les Paul Wireless Guitar Strummer Replacement: passo 5, immagine 3 di 3
    • Remove the two plastic holders on the underside of the chip.
    • Pull out the the plastic piece on each side of the strummer.
    • Lift the strummer out of it's location
  6. Les Paul Wireless Guitar Strummer Replacement: passo 6, immagine 1 di 3 Les Paul Wireless Guitar Strummer Replacement: passo 6, immagine 2 di 3 Les Paul Wireless Guitar Strummer Replacement: passo 6, immagine 3 di 3
    • Take the top black cover off the strummer.
    • Slide the black rod out of the side.
    • Clean if needed.
Conclusione
Altre 4 persone hanno completato questa guida.
Chris
Membro da: 10/18/13
881 Reputazione
6 Guide realizzate
4 Commenti
Hi recently bought this controller again and the up strum has stopped functioning. Hoping this will fix it. Thanks
liamiley91 - Replica
Did this fix your issue? Thinking about trying it.
D. Preston Peek -
Same here, i want to it try but want to know if i will be able to do it altough i’m not really good with these kind of work
Sébastien Fortuny - Replica
This guitar don't have star power with up guitar? Where is sensor?
Leandro Loureiro - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 28
Ultimi 30 Giorni: 106
Tutti i Tempi: 19,470
