Salta al contenuto principale
Les Paul Wireless Guitar Battery Pack Replacement
Cosa ti serve
  1. Les Paul Wireless Guitar Battery Pack Replacement, Les Paul Wireless Guitar Body Teardown: passo 1, immagine 1 di 1
    • Remove batteries
  2. Les Paul Wireless Guitar Battery Pack Replacement: passo 2, immagine 1 di 2 Les Paul Wireless Guitar Battery Pack Replacement: passo 2, immagine 2 di 2
    • Remove void warranty sticker
    • The sticker is covering a torx screw
  3. Les Paul Wireless Guitar Battery Pack Replacement: passo 3, immagine 1 di 3 Les Paul Wireless Guitar Battery Pack Replacement: passo 3, immagine 2 di 3 Les Paul Wireless Guitar Battery Pack Replacement: passo 3, immagine 3 di 3
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  4. Les Paul Wireless Guitar Battery Pack Replacement, Battery Pack: passo 4, immagine 1 di 2 Les Paul Wireless Guitar Battery Pack Replacement, Battery Pack: passo 4, immagine 2 di 2
    • Gently move the capacitor around until it breaks off
  5. Les Paul Wireless Guitar Battery Pack Replacement: passo 5, immagine 1 di 1
    • Solder on the new capacitor.
Conclusione
Altre 3 persone hanno completato questa guida.
Chris
Membro da: 10/18/13
881 Reputazione
6 Guide realizzate
2 Commenti
What cap is needed?
Martin Samuelsson - Replica
Mine is: 2200uF 10V
Thijs van Ulden -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 87
Tutti i Tempi: 12,161
