Salta al contenuto principale
Introduzione
Here, we will describe how to dissemble your camera in order to properly replace the lens cover.
Parti
Nessuna parte specificata.
  1. Unscrew the two small screws on the black side panel of the camera using a PH00 screwdriver. Remove the part.
    • Unscrew the two small screws on the black side panel of the camera using a PH00 screwdriver. Remove the part.
  2. You will need to remove the front panel in order to access the lens. Lift the latches on the side of the front panel to remove it entirely, pulling gently in an upward motion.
    • You will need to remove the front panel in order to access the lens. Lift the latches on the side of the front panel to remove it entirely, pulling gently in an upward motion.
  3. Locate silver lens covering.
    • Locate silver lens covering.
  4. Use your PH00 screwdriver to unscrew the lens cover.
    • Use your PH00 screwdriver to unscrew the lens cover.
    • Remove the screw.
    • Remove the lens cover.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 609
