Salta al contenuto principale
Lenovo bluetooth mouse N6901A disassembly
Cosa ti serve
  1. Lenovo bluetooth mouse N6901A disassembly, Mouse: passo 1, immagine 1 di 1
    • 3 Phillips screws are located under the battery cover, unscrew them
  2. Lenovo bluetooth mouse N6901A disassembly: passo 2, immagine 1 di 2 Lenovo bluetooth mouse N6901A disassembly: passo 2, immagine 2 di 2
    • The mouse cover at the bottom should move freely but at the top is hold by 2 brackets
    • In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
  3. Lenovo bluetooth mouse N6901A disassembly: passo 3, immagine 1 di 2 Lenovo bluetooth mouse N6901A disassembly: passo 3, immagine 2 di 2
    • At this point, you have separated the mouse cover
  4. Lenovo bluetooth mouse N6901A disassembly: passo 4, immagine 1 di 1
    • Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
  5. Lenovo bluetooth mouse N6901A disassembly: passo 5, immagine 1 di 2 Lenovo bluetooth mouse N6901A disassembly: passo 5, immagine 2 di 2
    • The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter
    • When you reassemble the mouse, make sure you don't crush the power cable
Conclusione
Shinn Chyang Chen
Membro da: 09/14/11
2.923 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 42
Tutti i Tempi: 5,510
