Salta al contenuto principale
Lenovo Yoga Tablet 2 830-F Motherboard Replacement
Cosa ti serve
  1. Lenovo Yoga Tablet 2 830-F Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Remove the two 3mm screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Remove the 2mm screw on the back fo the device with a Phillips #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Motherboard Replacement: passo 2, immagine 1 di 2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the six 3mm screws on the back of the motherboard with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components
    • Remove ZIF connectors connecting the boards to the electrical components.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Motherboard Replacement: passo 3, immagine 1 di 2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement: passo 3, immagine 2 di 2
    • Replace the motherboard with the new motherboard.
    • Be careful not to damage the ribbon cables when reassembling the device.
Conclusione
USF Tampa, Team S2-G4, Nance Fall 2017 Membro di USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,958
