Salta al contenuto principale
Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement
Cosa ti serve
  1. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement, Headphone Jack: passo 1, immagine 1 di 2 Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement, Headphone Jack: passo 1, immagine 2 di 2
    • Remove the two 3mm screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Remove the 2mm screw with a Phillips #00 bit.
    • Using the blue opening tool or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement: passo 2, immagine 1 di 1
    • Remove the three 2mm screws on the back of the left speaker module with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement: passo 3, immagine 1 di 1
    • Gently remove the left speaker module.
    • Replace the old left speaker module with the new left speaker module.
    • Be careful not to damage the ribbon cables on the new left speaker module while reassembling the device.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S2-G4, Nance Fall 2017 Membro di USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,923
