Salta al contenuto principale
Lenovo Yoga Tablet 2 830-F Camera Replacement
Cosa ti serve
  1. Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: passo 1, immagine 1 di 2 Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: passo 1, immagine 2 di 2
    • Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Camera Replacement: passo 2, immagine 1 di 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: passo 2, immagine 2 di 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: passo 2, immagine 3 di 3
    • Using the Phillips Screwdriver #00 bit remove the 6 screws.
    • Using the Phillips Screwdriver #00 bit remove the 3 screws.
    • After removing all the screws, disconnect the ribbon cables.
    • Disconnect the ZIF connectors.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Camera Replacement: passo 3, immagine 1 di 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: passo 3, immagine 2 di 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: passo 3, immagine 3 di 3
    • After removing the motherboard and antennas the camera module is located on the right as marked in red.
    • Remove the three 2mm screws holding the module in place with the Phillips Screwdriver #00 bit.
    • The camera module is also held in place with adhesive so gently remove.
Conclusione
Mario Gjyli
Membro da: 09/28/17
447 Reputazione
3 Guide realizzate
USF Tampa, Team S2-G4, Nance Fall 2017 Membro di USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 654
