Salta al contenuto principale
Lenovo Yoga Tablet 10 Wi-Fi Module Replacement
Cosa ti serve
  1. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the two Phillips #000 screws.
    • These screws are located behind the stand for the device.
    • Our device did not include these screws.
  2. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 2, immagine 1 di 1
    • Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
    • Do not immediately attempt to remove the back of the case without attempting Step three, or you risk snapping the back cover.
  3. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 3, immagine 1 di 2 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 3, immagine 2 di 2
    • Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
  4. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement, Back Camera: passo 4, immagine 1 di 2 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement, Back Camera: passo 4, immagine 2 di 2
    • Remove one 5mm screw using the Phillips #00 Screwdriver.
  5. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 5, immagine 1 di 3 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 5, immagine 2 di 3 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 5, immagine 3 di 3
    • Use the spudger to disconnect the camera and battery from the printed circuit board by putting the spudger in between the connections and the printed circuit board and pushing the spudger up.
  6. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 6, immagine 1 di 1
    • Remove one 5mm screw with the Phillips #00 screwdriver.
  7. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 7, immagine 1 di 3 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 7, immagine 2 di 3 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the nylon tip tweezers to push the camera out from between the power button and the kickstand.
  8. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement, Camera PCB: passo 8, immagine 1 di 1
    • Remove the four 1 mm screws with a Phillips #00 Screwdriver.
  9. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 9, immagine 1 di 2 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 9, immagine 2 di 2
    • Use a spudger to disconnect the ribbon wire by applying a force upwards.
  10. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 10, immagine 1 di 2 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 10, immagine 2 di 2
    Compra
    • Use tweezers to lift up the foil.
    • The foil may tear.
  11. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 11, immagine 1 di 2 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 11, immagine 2 di 2
    • Use the tweezers to lift the black tape from the corner of the printed circuit board.
  12. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 12, immagine 1 di 3 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 12, immagine 2 di 3 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 12, immagine 3 di 3
    • Flip the board 180 degrees towards you using the tweezers.
  13. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement, Wi-Fi Module: passo 13, immagine 1 di 2 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement, Wi-Fi Module: passo 13, immagine 2 di 2
    Compra
    • Remove the wire from the PCB by pulling it towards the edge of the headphone jack using tweezers.
  14. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 14, immagine 1 di 3 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 14, immagine 2 di 3 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 14, immagine 3 di 3
    • Remove the one 5mm screw using a Phillips #00 Screwdriver.
  15. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 15, immagine 1 di 3 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 15, immagine 2 di 3 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 15, immagine 3 di 3
    • Using tweezers remove the tape to disconnect the module by pulling it upward.
  16. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 16, immagine 1 di 2 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: passo 16, immagine 2 di 2
    • Remove the yellow piece of tape by pulling it upward using tweezers.
Conclusione
Cal Poly, Team S2-G6, White Winter 2019 Membro di Cal Poly, Team S2-G6, White Winter 2019
CPSU-WHITE-W19S2G6
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 392
