Introduzione
If you are following this guide, that means your screen of LCD is broken, cracked, or causing graphical issues on your Lenovo Yoga Tab 3 8. Before starting to work on your device, it is advised to back up any important files just in case something happens. You will want to make sure you have the device powered off to prevent harming yourself or damaging your hardware. To make reassembly easier, be sure to avoid misplacing the small screws by keeping track of them as you go. Be cautions as you remove the LCD, especially if it was previously cracked. The screen could shatter which will make removal more dangerous and difficult. It is recommended that you wear heavy duty gloves and safety glasses to avoid injury.
Cosa ti serve
Panoramica Video
Open the kickstand by pressing the release button in the center.
Remove the identification sticker with a pair of tweezers to allow access to the two 2mm screws underneath.
With the device oriented screen side down and hinge opposite of you, locate the LCD connection on the motherboard. It is the small copper and white connector to the left of the kickstand lock. Disengage the lock on the connector by flipping it up with a pair of tweezers. Use the tweezers to then pull the wire out of the connector.
On the right edge of the motherboard, locate the large brown and black LCD connection. Disengage the lock and pull the wire out of the connector with the tweezers.
Heat the iOpener and lay it flat along an edge of the LCD for 2-5 minutes to loosen the screen adhesive.
Insert a plastic opening tool under the LCD and gently pry it away from the adhesive. Place opening picks as you go along all four edges to keep the adhesive from sticking again.
Altre 6 persone hanno completato questa guida.
3 Commenti
Do I need to add glue when reinstalling the lcd?
Yes but very little and I prefer to use araldite Or fevibond
While repairing I forgot to keep the black ribbon located at the right corner of the motherboard what should I do
