Salta al contenuto principale
Lenovo Yoga Tab 3 10 Wifi Module Replacement
Cosa ti serve
  1. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Back Cover: passo 1, immagine 1 di 1
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 2, immagine 1 di 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 2, immagine 2 di 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 2, immagine 3 di 3
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 3, immagine 1 di 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 3, immagine 2 di 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 3, immagine 3 di 3
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: passo 4, immagine 1 di 2 Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: passo 4, immagine 2 di 2
    • Use the nylon spudger to gently lift the foil cover of the wifi model.
  5. Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to gently lift the gold tape located above the copper foil.
  6. Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 6, immagine 1 di 1
    • Use the plastic spudger to disconnect the wifi module connector from the motherboard.
  7. Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 7, immagine 1 di 2 Lenovo Yoga Tab 3 10 Wifi Module Replacement: passo 7, immagine 2 di 2
    • Carefully lift the wifi module from the device.
Conclusione
Phanudej
Membro da: 02/20/17
1.184 Reputazione
5 Guide realizzate
USF Tampa, Team S3-G2, Sullivan Spring 2017 Membro di USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
4 Membri
18 Guide realizzate
Un commento
where can i buy this type of module?
rebeca rackolavsci - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 34
Tutti i Tempi: 3,469
