Salta al contenuto principale
Lenovo Yoga Tab 3 10 LCD Replacement
Cosa ti serve
  1. Lenovo Yoga Tab 3 10 LCD Replacement, Back Cover: passo 1, immagine 1 di 1
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 LCD Replacement: passo 2, immagine 1 di 3 Lenovo Yoga Tab 3 10 LCD Replacement: passo 2, immagine 2 di 3 Lenovo Yoga Tab 3 10 LCD Replacement: passo 2, immagine 3 di 3
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3 10 LCD Replacement: passo 3, immagine 1 di 3 Lenovo Yoga Tab 3 10 LCD Replacement: passo 3, immagine 2 di 3 Lenovo Yoga Tab 3 10 LCD Replacement: passo 3, immagine 3 di 3
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3 10 LCD Replacement, LCD: passo 4, immagine 1 di 3 Lenovo Yoga Tab 3 10 LCD Replacement, LCD: passo 4, immagine 2 di 3 Lenovo Yoga Tab 3 10 LCD Replacement, LCD: passo 4, immagine 3 di 3
    • Before detaching the LCD and digitiser connectors, remove the two small screws at the top left (red bordered area in photo). Remove the metal shield and disconnect the battery wire.
  5. Lenovo Yoga Tab 3 10 LCD Replacement: passo 5, immagine 1 di 3 Lenovo Yoga Tab 3 10 LCD Replacement: passo 5, immagine 2 di 3 Lenovo Yoga Tab 3 10 LCD Replacement: passo 5, immagine 3 di 3
    • With tweezers, lift the locking flaps and detach the connected ribbon cables for both the LCD and digitizer (blue bordered areas in previous step photo)
    • Using a spudger lift the gold- colored base up away from the adhesive.
    • This particularly ribbon connection will likely be difficult to detach from the casing. Proceed with patience and caution during removal process.
    • Check your replacement LCD to see if it includes a new ribbon cable (black one in second photo). If not, you'll need to peel up the tape securing it, and disconnect it at the LCD end instead of the motherboard end.
  6. Lenovo Yoga Tab 3 10 LCD Replacement: passo 6, immagine 1 di 1
    • Using the iOpener place it along the edges of the device to weaken the adhesive.
    • The applied heat is strictly to loosen the adhesive portion around the perimeter and should not come in contact with the LCD.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  7. Lenovo Yoga Tab 3 10 LCD Replacement: passo 7, immagine 1 di 3 Lenovo Yoga Tab 3 10 LCD Replacement: passo 7, immagine 2 di 3 Lenovo Yoga Tab 3 10 LCD Replacement: passo 7, immagine 3 di 3
    • Using the plastic opening tools separate the screen from the device.
    • Proceed with patience. Applying too much pressure and force here can result in damage to the delicate glass panel or underlying LCD.
  8. Lenovo Yoga Tab 3 10 LCD Replacement: passo 8, immagine 1 di 1
    • Lift the screen gently from the device.
    • Make sure the cable ribbon is pulled through safely.
    • Some adhesive may still be connected so be patient when removing the screen.
Conclusione
Altre 18 persone hanno completato questa guida.
Phanudej
Membro da: 02/20/17
1.184 Reputazione
5 Guide realizzate
USF Tampa, Team S3-G2, Sullivan Spring 2017 Membro di USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
4 Membri
18 Guide realizzate
9 Commenti
Hello where can I find a replacement screen and digitizer please?
Hend Farid - Replica
Decir ahaepwjw098
monic119 - Replica
how can i change digitizer only?
Fernando Benitez - Replica
Isn’t this about changing the glass screen instead of the LCD as the title says?
Mohamed hemsas - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 111
Tutti i Tempi: 30,583
