Introduzione
Before you start get a correct replacement screen. Find the exact model name of your tablet. You can find it in "About the tablet", at the bottom of the Android settings app. Search online for the part and buy from a reputable seller.
Cosa ti serve
Before detaching the LCD and digitiser connectors, remove the two small screws at the top left (red bordered area in photo). Remove the metal shield and disconnect the battery wire.
With tweezers, lift the locking flaps and detach the connected ribbon cables for both the LCD and digitizer (blue bordered areas in previous step photo)
Using a spudger lift the gold- colored base up away from the adhesive.
Altre 18 persone hanno completato questa guida.
9 Commenti
Hello where can I find a replacement screen and digitizer please?
how can i change digitizer only?
Isn’t this about changing the glass screen instead of the LCD as the title says?
