Salta al contenuto principale
Lenovo Yoga Tab 3 10 Camera Replacement
Cosa ti serve
  1. Lenovo Yoga Tab 3 10 Camera Replacement, Back Cover: passo 1, immagine 1 di 1
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Camera Replacement: passo 2, immagine 1 di 3 Lenovo Yoga Tab 3 10 Camera Replacement: passo 2, immagine 2 di 3 Lenovo Yoga Tab 3 10 Camera Replacement: passo 2, immagine 3 di 3
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3 10 Camera Replacement: passo 3, immagine 1 di 3 Lenovo Yoga Tab 3 10 Camera Replacement: passo 3, immagine 2 di 3 Lenovo Yoga Tab 3 10 Camera Replacement: passo 3, immagine 3 di 3
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3 10 Camera Replacement, Camera: passo 4, immagine 1 di 3 Lenovo Yoga Tab 3 10 Camera Replacement, Camera: passo 4, immagine 2 di 3 Lenovo Yoga Tab 3 10 Camera Replacement, Camera: passo 4, immagine 3 di 3
    • Remove the 3 screws from the auxiliary port cover.
    • Use the spudger to gently push the auxiliary module out of the way.
    • Remove the detachable plastic latch located in front of the hinge.
  5. Lenovo Yoga Tab 3 10 Camera Replacement: passo 5, immagine 1 di 1
    • Use a spudger to gently remove the hinge.
  6. Lenovo Yoga Tab 3 10 Camera Replacement: passo 6, immagine 1 di 1
    • Carefully lift the kickstand away from the frame.
    • The battery is located inside of the kickstand. Ensure proper handling and care.
  7. Lenovo Yoga Tab 3 10 Camera Replacement: passo 7, immagine 1 di 2 Lenovo Yoga Tab 3 10 Camera Replacement: passo 7, immagine 2 di 2
    • Use the pointed end of a spudger to push in the camera's locking mechanism.
    • Upon releasing the camera lock lift the camera out and locate the three screws.
  8. Lenovo Yoga Tab 3 10 Camera Replacement: passo 8, immagine 1 di 3 Lenovo Yoga Tab 3 10 Camera Replacement: passo 8, immagine 2 di 3 Lenovo Yoga Tab 3 10 Camera Replacement: passo 8, immagine 3 di 3
    • Use a J000 Philips screwdriver to remove the three screws.
    • Remove the camera cover that seals the camera case.
    • Remove the camera from the shell.
  9. Lenovo Yoga Tab 3 10 Camera Replacement: passo 9, immagine 1 di 1
    • Separate the camera from its casing.
Conclusione
Altre 2 persone hanno completato questa guida.
Phanudej
Membro da: 02/20/17
1.184 Reputazione
5 Guide realizzate
USF Tampa, Team S3-G2, Sullivan Spring 2017 Membro di USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
4 Membri
18 Guide realizzate
Un commento
Thanks for describing in details with bit and peaces very neatly and clearly. I fix the problem of my Lenovo Yoga 3 with help of this. Great job you have done.. keep it up… Sisira
Sisira Kumara - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 26
Tutti i Tempi: 4,120
