Salta al contenuto principale
Lenovo Yoga Tab 3 10 Motherboard Replacement
Cosa ti serve
  1. Lenovo Yoga Tab 3  10 Motherboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 2, immagine 1 di 3 Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 2, immagine 2 di 3 Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 3, immagine 1 di 3 Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 3, immagine 2 di 3 Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 3, immagine 3 di 3
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3  10 Motherboard Replacement, Motherboard: passo 4, immagine 1 di 3 Lenovo Yoga Tab 3  10 Motherboard Replacement, Motherboard: passo 4, immagine 2 di 3 Lenovo Yoga Tab 3  10 Motherboard Replacement, Motherboard: passo 4, immagine 3 di 3
    • Locate the screws in the motherboard the wire cover assembly and the speakers.
    • Use the J000 screwdriver to remove the screws on the motherboard, the wire cover, and the two speakers.
    • Disconnect the wifi connector on the motherboard.
  5. Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 5, immagine 1 di 2 Lenovo Yoga Tab 3  10 Motherboard Replacement: passo 5, immagine 2 di 2
    • Use the spudger to lift the two speakers up from the small adhesive strip.
    • Place the spudger in the upper left corner of the motherboard and lift it to separate it from the adhesive strip under it.
    • Lift away the motherboard.
Conclusione
Altre 13 persone hanno completato questa guida.
Phanudej
Membro da: 02/20/17
1.184 Reputazione
5 Guide realizzate
USF Tampa, Team S3-G2, Sullivan Spring 2017 Membro di USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
4 Membri
18 Guide realizzate
Un commento
Dear @phanudej ,
I liked your post. I’d have a remark and a question. I made a mistake during the maintanance; with wich I killed a part of the MOBO. So dear users my advice if you want to connect the LCD connector remove the battery before… I had never this issue but now happened. (the device was switched off)
Could you please take a photo of the powerstage of the LCD (I think it should be that) So between the inductor (100; 10uH coil) and an capacity there is a component I do not know what is it (it smoked away) I assume it is a diode…?! They are in the white rectangle near the LCD connector
Thanks in advance
Best regards
@harrincourt
Jozsef Szlatki - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 35
Tutti i Tempi: 9,177
