Salta al contenuto principale
Lenovo Yoga C930-13IKB SSD Replacement
Cosa ti serve
  1. Lenovo Yoga C930-13IKB SSD Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB SSD Replacement: passo 2, immagine 1 di 2 Lenovo Yoga C930-13IKB SSD Replacement: passo 2, immagine 2 di 2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB SSD Replacement: passo 3, immagine 1 di 2 Lenovo Yoga C930-13IKB SSD Replacement: passo 3, immagine 2 di 2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB SSD Replacement, SSD: passo 4, immagine 1 di 1
    • Remove the screw ( 2 mm with a 5 mm head) that connect the SSD to the motherboard using a Phillips #00 screwdriver.
  5. Lenovo Yoga C930-13IKB SSD Replacement: passo 5, immagine 1 di 1
    • Pinch the left side of the SSD card.
    • Pull gently to the left, horizontal to the laptop.
Conclusione
Cal Poly, Team S19-G5, White Winter 2020 Membro di Cal Poly, Team S19-G5, White Winter 2020
CPSU-WHITE-W20S19G5
4 Membri
16 Guide realizzate
4 Commenti
I need to remove the stripped screw on the SSDs non-slot-end because Lenovo tightened it down with a military grade drill. To replace, it wasn’t mentioned which size screw was there.
John Tullos - Replica
Ty for the info but I'm looking to get windows installed onto the blank new hard drive so I can actually run and use it, lol! Unfortunately, the "automatic" registration process didn't work and my product key isn't to be found. In fact, my Microsoft account doesn't even have it registered as a device. But it does have it as a device I loaded apps from the Play Store though. So, there's proof it existed. Anywho, I'm stuck trying to get Windows on it before I re-install the hard drive. Any ideas are more than welcome! Thanks, M.H.
Mac Daditink - Replica
Good guide. I took the following steps and it went quickly and smoothly. Less than an hour start to finish:
1. I purchased a Samsung 980 (not Pro, but should also work).
2. Disabled bitlocker on my old SSD. I also backed up the key for future ref.
3. Downloaded and installed the Samsung SSD Magician and migration tools.
4. Put the new SSD into an external enclosure ($18 on Amazon).
5. Ran the migration software and copied my windows 11 to the new SSD.
6. Shutdown the laptop and swapped the SSDs.
7. Rebooted into windows.
8. Ran the Samsung Magician software and updated the SSD firmware.
9. Done and perfect.
Thomas Harding - Replica
THANK YOU, THOMAS!!! I did exactly these things and now my C930 has been running flawlessly for a week now! It is now, once again, my favorite laptop despite its age. :-) You saved me quite a bit of time.
Notes for others: 1) I didn't do Step 8.
2) Here's the enclosure I ordered: https://www.amazon.com/dp/B0BWXDT8TB?ref...
3) The Samsung Magician software can be found at https://semiconductor.samsung.com/us/con...
Gary Friedman -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 66
Tutti i Tempi: 5,965
